It is currently Fri Aug 08, 2025 7:08 am
 Post subject: Epoxy OVER Nitro
PostPosted: Sat Jan 06, 2018 4:55 pm
First name: Gary
Last Name: Leddington
Does anyone foresee problems putting a thin layer of epoxy over nitro then finishing with nitro again?
www.leddingtonguitars.com
 Post subject: Re: Epoxy OVER Nitro
PostPosted: Sat Jan 06, 2018 5:39 pm
City: Tyler
Why would you need to?
PostPosted: Sat Jan 06, 2018 6:21 pm
First name: Gary
To fill some dents in a backstrip i missed before spraying...
Anyway... any problems forseen?
PostPosted: Sat Jan 06, 2018 7:15 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Do not do that. Show some pictures and let’s go from there
PostPosted: Sat Jan 06, 2018 7:51 pm
City: Tyler
I routinely spray a wash coat of nitro on back and sides before pore filling with epoxy just to trap the dust but I wouldn’t fill with epoxy on a full finish. Just drop fill with nitro.
PostPosted: Sat Jan 06, 2018 9:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
If the dents are small, drop fill with nitro. If this involves big dents, I dunno. But I would not use epoxy for this. Pics of dents please.
PostPosted: Sun Jan 07, 2018 7:49 am
First name: Gary
Cant send pics right now... but thanks for the tips.... i will drop fill and build it up with nitro....
PostPosted: Sun Jan 07, 2018 8:47 am
First name: Gary
However... now i am curious... what would happen if you put epoxy over nitro, level sanded then then re-finished with nitro?
PostPosted: Sun Jan 07, 2018 10:00 am
"However... now i am curious... what would happen if you put epoxy over nitro, level sanded then then re-finished with nitro?"
It's hard to say. There are a lot of different formulations of epoxy. Dissimilar finishes "move" differently with changes in temperature and humidity. Generally it is not recommended to use a softer finish under a harder one, although a very thin coat of shellac seems to be an exception to this rule. Putting a finish both over and under another might be asking for trouble. But then again you might get away with it.
PostPosted: Sun Jan 07, 2018 12:11 pm
Online
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
The main reason I wouldn't do it is that it might show after final buff. Not saying that it would. Drop fill with nitro I would consider
to be the safe route.
Ken
PostPosted: Sun Jan 07, 2018 5:45 pm
That is the wrong way to address the issue. Take some nitro lacquer and set it out for a few days. Like 1/4 oz in a cup. I keep a small squeeze bottle (1/2 I want to say) with nitro that has evaporated out to where it is more of a thick paste. It should flow like molasses. You can use that to fill the voids. It will melt into the existing lacquer and shrink some. You need to give it 3 weeks (ideally) to cure before scraping flat, wet sanding, and buffing.
Andy
PostPosted: Sun Jan 07, 2018 6:05 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It could end up looking like crap. Seriously. Can you imagine a major builder doing that? The suggestion above about evaporating some nitro down to molasses viscosity is precisely what I do. Keep it in a squeeze bottle suitable for nitro (nylon). Something like that will create an invisible fix. Unless it’s on the top. The downside is u really need to spend the time on the cure. A warm hairdryer could speed it up. Indirect application of course.
PostPosted: Mon Jan 08, 2018 9:24 am
The cardinal rule of cabinetmaking is NEVER mix finishes.
These users thanked the author Haans for the post: Ken Jones (Tue Jan 09, 2018 10:54 pm)
Users browsing this forum: guitarjtb, Ken Lewis and 35 guests
